12-14-2004 02:23 PM
12-15-2004 11:27 AM
12-15-2004 01:39 PM
12-16-2004 09:34 AM
12-20-2004 10:22 AM
12-21-2004 09:12 AM
Can you give some additional details of the behavior you are experiencing on the AMD computer? It sounds like if you increase the update rate beyond a certain rate, then your program executes but you don't see a signal on your AO channels. Is this correct?
Are you checking for errors in your program? If so, do you get any errors? Are you using NI-DAQmx or Traditional NI-DAQ to communicate with your hardware?
It also sounds like you are performing AO and AI in the same application. Have you tried to run a simple AO example that ships with NI-DAQ?
12-22-2004 09:58 AM
