Multifunction DAQ
Reply
Lumasense Pyrometer Wiring on the NI cDAQ 9203
Highlighted
Looking for help wiring a Lumasense IN 5/5L+ pyro on the 9203.  I have the power supply feeding the pyro, the analog signal going from the pyro to the 9203, ch1/COM.
It's reading 4mA no matter what i do.  Any help would be much appreciated.
(270 Views)
Re: Lumasense Pyrometer Wiring on the NI cDAQ 9203
Hi coolhandLV7,
This National Instruments page should be a helpful resource when wiring your device.  The page explains how to find your device pinout, how to configure current measurement and how to test the signal.
If you run into any problems with noise this "Field Wiring and Noise Considerations for Analog Signals" guide will be a good reference.
-cblanchard
(231 Views)
