Multifunction DAQ
Looking for (2) VXI-MIO-64E-1 for purchase
All,
I am currently looking for (2) VXI-MIO-64E-1 multifunction cards for purchase. If you have any cards you wish to sell or know of any cards forsale, please contact me at...
Roger A. Coffmon
Senior Design Engineer, ATE
roger.coffmon@liebert.com
614-841-5871
Liebert, NA
www.liebert.com
Emerson Network Power
www.gotoemerson.com
"Consider It Solved"
(2,419 Views)
Roger,
Don't have what you are looking for but depending on your VXI controler there may be an alternative for you to consider. If you are using an embedded controler with a PCI expansion slot (such as 872B or 875B)you can always opt to use a PCI Data Acquisition board that meets your needs. The PCI equivalent board to the VXI-MIO-64E-1 is the PCI-6071E. You can find the product specs at the following location - http://sine.ni.com/apps/we/nioc.vp?cid=1042〈=US. This board has the functioanality equivalence with one exception, the onboard memory. So assuming you are not using the onboard memory option for the VXI-MIO-64E-1 you should have both programming and functionality transparancy.
Christer
(2,414 Views)
Christer,
All great suggestions but, I do not have these options available to me.
-Roger
(2,401 Views)
