08-26-2015 02:55 AM - edited 08-26-2015 03:09 AM
i need some assistance regarding a NI 9219 DAQ module, controlled in Labview, basically i have 2 separate case structures and one DAQ assistant in each case. When i need to switch between them i get an error from DAQ ''this specified resource is reserved'', something like that. I have data aquisition from 3 different chanells simultaneously. How can i fix this?
Thanks in advance!!
08-26-2015 03:42 AM
08-26-2015 04:12 AM
I need to discharge a battery for x minutes, then stop for y minutes and so on until a condition is verified, and i used a state machine architecture, but now i solved the problem, the resource had to be stopped before switching. On the other hand which is the best solution to export data from DAQ, i am currently using Write to Meas File. I want to export all the data in the same file
Thanks!
08-26-2015 07:27 AM
I prefer using the Logging function DAQmx to stream the data to a TDMS file. Much more efficient than anything else you come up with. But you will want a single task. I advise to get away from using the DAQ Assistant and actually use the DAQmx API. Things will become a lot easier on you for situations like this. Instead of a new task, you should just be writing different data.
09-01-2015 10:15 PM
I can not find icon DAQ Acquisition in LabView on table Function ->Input.Have we connect card DAQ with PC before started with Labview,haven't?.
09-02-2015 01:57 AM
