I'm not sure what more to tell you. The 6034E was baught from a third party vendor, ATI, to read their 6-degree-of-freedom force transducer. I have a 6025E that I'm reading
one of the DAC outputs from the 7344 board and a linear pot. they worked fine to begin with. The 6034E works fine alone in ANOTHER computer. The 6034E works fine in
my computer without the motor board. Reinstalling the motor board in the computer, last night, seems to have caused channel 6 of the 6034E board to saturate to 10 volts. This
is different from what happened when the 6034E was added in the first place. It seems the behavior is dependent on which board is added first. Yes, and the 7344 continues to
put out 12.6 volt max on the +-10 volt DAC
Jim Fee
