Is it necessary to preconfigure input mode in MAX prior to writing program in Measurement Studio?
If my E-Series device properties Analog Input Mode in MAX is set to Referenced Single Ended, can I still over-ride in code from VB to read Differential mode?
(2,323 Views)
You can do it using VB. Please make sure that if you are changing the input mode (CWAIChannel.inputmode) or you can use functional call to change it too.
(2,323 Views)
