Multifunction DAQ
Increasing memory consumption with time
Greetings,
I have a MCC DAS1000 and usb3102 card. When I check the memory counsumption of the PC I see it increasing with time until at some point the PC freezes and I have to restart.
What may cause this problem, any help appreciated greatly! (PC: XP SP3 1GB Ram AMD64 X2 CPU)
PS: The code is attached
Best Regards Ferhat
(2,982 Views)
Accepted by topic author ferro44
Move all of your creating of channels to be BEFORE your loop.  You are causing memory leaks since you just keep creating new references without closing the "old" ones.
GCentral
(2,961 Views)
