Multifunction DAQ
Increasing input impedance on a PXIe-6535?
I need to significantly increase the input impedance on the IO lines while maintaining rise and fall times.  I was thinking of adding 1-2 meg ohm resistors in series with the IO lines on the breakout boad, but if the parasitic capacitance on the PXIe-6535 is too high, I would be forced to a lower sampling rate, due to the charge/discharge time.
Or is there a way to make the 6535 completely "let go" of an IO line?  Tri-stating forms a resistor divider when an IO line has an external 20k pull up.  I need the PXIe-6535 to drive some IO lines that have very high-value pull ups with open-drain.
(3,605 Views)
Hey CurtisHx!
It looks like you may have posted this question on the wrong board for the product type. If you repost this question to the Digital I/O board, you are more likely to receive help from the community members that are familiar with the high speed DIO cards!
Mena S.
Applications Engineering
(3,568 Views)
I was under the impression that the PXIe-6535 was classified as a DAQ card since it uses the .NET DAQmx library.  Let that be a lesson in making assumptions......
(3,560 Views)
The most important information(s) are missing!
Needed timing resolution ?
If you need ns high speed you need matched impedances (and these are usually low impedances 50 Ohm to 100 Ohm ... and a meter cable is about 5ns 😉 )
So: What do you want to measure?  Source ? Impedances?
(one solution migth be a 'simple' DIY FET probe adapted to DC ...  atually a FET voltage follower )
here is an AC version .... but you would need to adapt it to DC and match the impedances to a DI ...  (wasn't that 100 Ohm?  Than a twisted cable pair (Cat-cable) should fit)
http://www.seekic.com/blog/project_solutions/2011/08/03/Poor_Man%E2%80%99s_1_GHz_Active_Probe__DIY_S...
http://teledynelecroy.com/doc/probes-probing
Greetings from Germany
Henrik
LV since v3.1
(3,535 Views)
