07-07-2005 07:34 PM
I have 3 USB-6008 DAQs. All of them appear to be exhibiting some sort of error in reading voltage.
I am using Windows XP Pro, NI Datalogger (v7?). I have NIDAQmxBase 1.5 also installed.
My problem is that I am not getting values that I expect. I am trying to read the value of 1.5 volt AA battery.
Of the 3 units (USB-6008) that I have, first unit, channel 1 does not read proper values but channel 2, 3 and 4 works fine. On the second unit channel 1 and 2 gives me incorrect values while channel 3 and 4 works fine. On the third unit, all channels give me incorrect values.
For the incorrect values that I am seeing, some seems to be offset issue where it is -1.0 when it should be 1.4 while other channels just gives me completely incorrect values (jumping around as if nothing was connected).
Here are things I have tried:
1. Removed the connectors and attached the leads directly to the unit.
2. Tried different batteries and used multimeter to confirm correct values.
Also, I have not connect the leads incorrectly (I checked multiple times).
Is this a calibration issue or are my units busted?
07-08-2005 10:05 AM
07-08-2005 10:33 AM
07-08-2005 11:08 AM
07-08-2005 11:36 AM
07-08-2005 12:01 PM
07-08-2005 12:06 PM
