Multifunction DAQ
Hysteresis Current Control using NI myDAQ
Hello everyone,
I need to design a current controlled DC to AC Inverter using hysteresis Band current controller technique. I am designing the controller using labview.
Here is the diagram for the principle of hysteresis band current controller.
And here is my VI:
My problem is that DAQ assistant is forcing me to send a sample of data (4000 samples in this case) rather than a single data. I was able to send stream of single data when using 'One sample per demand ' in daq assistan but the problem is that it is not outputing signals at the real frequency. I have also attached my VI and sub VI below.
Any suggestion about how i can send output stream of signal data at Daq assistant block 'Trigger' rather than a sample, and keeping the real frequency.
Thank you very much 🙂
Note: Reference Current: Simulate Signal
           Actual Current: Current/Voltage Measurement
           Output Pwm: Trigger
(6,201 Views)
Hello keshavsew,
I would consider using our DAQmx functions.  An example of how to wirte continuous analog output is included below:
https://decibel.ni.com/content/docs/DOC-34720
You can find more examples like this in the LabVIEW help by navigating to Help >> Find Examples in LabVIEW.
Best wishes!
Amanda B.
(6,157 Views)
Thank you very much for your reply. The problem with continous data, is that i need to send a sample of data (much more than one). However in my case, i need to send only one sample at a time to be able to track the current, at a rate about 50KHz.
Is it possible?
Thank you very much
(6,143 Views)
Hello keshavsew,
It really depends on your hardware.  I didn't see it listed in your post, but I would suggest googling your device online and then looking into its manuals and specification documents for information on its limitations.
Best wishes!
Amanda B.
(6,120 Views)
Hello Amanda,
My apologies, i forgot to mention the hardware. I am using NI myDAQ
Thank you
Keshav
(6,116 Views)
Hello keshavsew.
These are the documents I mentioned:
SPECIFICATIONS NI myDAQ
http://www.ni.com/pdf/manuals/373061f.pdf
USER GUIDE NI myDAQ
http://www.ni.com/pdf/manuals/373060f.pdf
In the first one, I think you'll find your answer.
Amanda B.
(6,090 Views)
