Multifunction DAQ
How to route the ctr0 in DAQ MX for PXI 6229?
The counter ctr0 of the PXI 6229 is internally wired to PFI12.
How could i change the terminal on which this counter is wired? What is the function in LabWindows CVI 7.1 (NI_DAQ MX 7.3) should be used? Is there any example of this? (in all the CVI example the fact that we have to connect the counter to a terminal is just mentioned)
Thanks for your help!
guyom
(2,790 Views)
You can change the output terminal on M Series devices using the following function:
int32 __CFUNC DAQmxSetCOPulseTerm(TaskHandle taskHandle, const char channel[], const char *data);
On M Series devices you can route the output of a counter to any PFI line.
I hope this helps!
gus....
(2,788 Views)
