07-24-2014 10:28 AM
I've been trying to use a code example for generating an analog output with the USB-6009 device and having trouble. I would try to set the generation for continuous and at a rate of 2000 pts/s and would get error messages. I even used the DAQ Assistant, selected continuous for the type, and it gave the same error messages. I understand now that the USB-6009 cannot generate a continuous waveform, and that's why I was getting the error messages. My question is whether a matrix or chart exists that shows which NI-DAQmx functions work with given devices. In this context, I go to the library to select a function, and have no idea if it will be supported by my device or not. The device documentation only says "All updates of analog output channels are software-timed"; to someone without a lot of experience, that doesn't stand out as "the device does not support continuous generation, your application controls all changes". That said, I would think that even someone with a lot of experience could benefit from a matrix of which DAQmx functions are supported by a given device. Seems that it would be in documentation for the device. Does such a listing for a given device exist?
07-24-2014 12:48 PM
This is related to the question that asked below, regarding which devices support NI-DAQmx Trigger. You would think that this information would be readily available since it is essential for deciding which product to purchase.
07-24-2014 01:08 PM
07-24-2014 01:56 PM
You are making the problem sound a more difficult than it is. Everything is secondardy to the DAQmx function list. I would not be that difficult to put together an spreadsheet listing what is and isn't supported for a given piece of hardware.
07-24-2014 02:43 PM
07-24-2014 03:02 PM
07-24-2014 03:47 PM
