09-09-2015 10:58 AM
I'm using LabWindows/CVI and when doing a DaqmxStartTask, I get the error : "Requested Value is not a supported value for this property."
This message was obtained by calling DAQmxGetErrorString with the status code returned by DaqmxStartTask.
QUESTION: Is there a way to know which property has an unsupported value ??
Thank you
09-14-2015 02:39 AM
Which hardware do you want to use? What kind of acquisition do you try to realize?
Could you provide your code ?
Regards
Samuel G. | GEMESIS
Certified LabVIEW Architect
Certified TestStand Developer
09-22-2015 05:32 PM
I'm using LabWindows CVI8.0.1 to generate some numeric data on a PCIe-6353. All configuration is ok (I mean configuration of channels, clocks etc.) but when I'm calling DAQmx_StartTask, I get the message "Requested Value is not a supported value for this property." and the task does not start.
=> Is there a way to know which parameter is not supported ?
Thx
