02-26-2012 08:52 PM
I'm using a USB 6009 to capture data on three separate channels. However, the way I have it set up now, I see all three channels on one plot. I'd like to see each channel on a separate plot but I'm not sure how I would do that. Thanks for your help.
Solved! Go to Solution.
02-27-2012 09:37 AM
You simply need an Index Array function.
02-27-2012 02:19 PM
Hi Aparker,
Here's a quick picture of what you could do with the Index Array Function to separate your plots onto separate graphs.
02-27-2012 04:45 PM
That worked. Thanks!
