since you've installed LV 7.1, I'd recommend you to use the DAQmx API instead of the Traditional DAQ. To generate a pulse train, you could also use one of the counters on the 6036. As start point you adapt the Gen Dig Pulse Train - Continuous VI to your needs. Alternatively, if you wanna generate an analog voltage, prefer the Cont Gen Voltage Wfm-Int Clk-Non Regeneration VI. The automatic regeneration of data is disabled in this example, so make sure that new data is provided throughout the duration of the continuous Analog Output operation.
Philippe Goetz,
Applications Engineer, NI
