Teddybare,
Since the DAQPad-6020E is not supported by NI-DAQmx, you will need to use Traditional NI-DAQ to program this device. Numerous Traditional NI-DAQ examples for use in VC++ are available in the following location:
C:\Program Files\National Instruments\NI-DAQ\Examples\VisualCAdditionally, the following KnowledgeBase explains how to use these examples in VC++:
KnowledgeBase: How to Compile and Run NI-DAQ Examples with Microsoft Visual C++Finally, the
Traditional NI-DAQ Function Reference Help provides documentation for all of the Traditional NI-DAQ functions. This resource is available in the following location:
>Start >> Programs >> National Instruments >> NI-DAQGood luck with your application.
Spencer S.
