Multifunction DAQ
How do i record data at low sampling rates?
I would like to make a long term measurement of a dc power supply to check the voltage stability. So I used DAQ-assistant at a sampling frequency of 0.01Hz but it gives me an error saying that DAQ is unable to record and that I need to set longer read timeout.
What is read timeout and how do I configure to make the measurement mentioned above?
I am using NI 6363 DAQ which has a maximum sampling rate of 2 Mega samples/sec. But is there any lower bound on the sampling rate?
(3,356 Views)
Please supply your VI so that we can actually help you troubleshoot.
GCentral
(3,342 Views)
You could sample at a higher rate but only keep the data from reads every now and then. Is there a reason you don't want to sample faster than 0.01 Hz?
Brandon Grey
Certified LabVIEW Architect
(3,312 Views)
