How do I pass a pointer to a TaskHandle in DAQmx?
I have a small problem
understanding how can I pass a pointer to a TaskHandle inside a class:
mycard.h
#include "NIDAQmx.h"
class mycard
public:
mycard();
~mycard();
uInt32 init();
uInt32 start(TaskHandle myHandle);
private:
TaskHandle mytaskHandle;
uInt32 status;
mycard.cpp
#include "mycard.h"
mycard::mycard()
mytaskHandle=0;
status=0;
mycard::~mycard()
uInt32 mycard::init()
status = DAQmxCreateTask("",mytaskHandle);
if(status!=0)
return status;
status =
DAQmxCreateAIVoltageChan(*mytaskHandle,"Dev1/ai0","",DAQmx_Val_NRSE,-10.0,10
.0,DAQmx_Val_Volts,NULL);
if(status!=0)
return status;
status = DAQmxCfgInputBuffer(*mytaskHandle,1000);
if(sta
tus!=0)
return status;
status =
DAQmxCfgSampClkTiming(*mytaskHandle,"",1000.0,DAQmx_Val_Rising,DAQmx_Val_Con
tSamps, 1000);
if(status!=0)
return status;
return status;
uInt32 mycard::start(TaskHandle myHandle)
status = DAQmxStartTask(myHandle);
return status;
When I call the start function, it reports error -200088, Task specified is
invalid or does not exist. If I call "DAQmxStartTask" in the Init function
it works well. My understanding is that I'm not passing the right pointer to
the task. How should a pointer to a TaskHandle be passed?
Laurentiu
(2,353 Views)
Hello laurentiu,
If I understood correctly what you are trying to do, you do not need a pointer to TaskHandle.
Just use your handle declaration: "TaskHandle mytaskHandle;"
Then pass the address for the handle in the DAQmxStartTask function: "status = DAQmxCreateTask("", &mytaskHandle);"
In the other functions from init just use the "mytaskHandle" value ex:"status = DAQmxCfgInputBuffer(mytaskHandle, 1000);"
The implementation of the start function is ok, and should remain unchanged.
Hope this helps,
krs
(2,353 Views)
