I m designing a controller and I need to output a voltage every 0.02 ms (50Hz). I can see how to do that with the WFM function after loading a buffer. In my case, the next voltage output is recomputed between each iteration: I cannot load output values in advance. Thanks for help.
If you know ahead of time what kind of signal to output, pre_generate it and then output it using one of the examples of buffered generation. A problem with timed loop may arise if the time it takes to execute the Analog output write command is way more than 0.02 seocnds (which can be the case)
