If you have support for Traditional NI-DAQ installed, you should have the option to open a configuration file from: Tools>>Traditional NI-DAQ Configuration>>Set Active Configuration. You can check the installation of Traditional NI-DAQ under the Software tree in MAX.
Hope this helps.
Erin
