Multifunction DAQ
How do I import Traditional NI-DAQ Virtual Channels and MAX 3.1
I installed Labview 7.1 on a new machine and the tools option in MAX 3.1 does not have the option to import traditional NI-DAQ configurations.
(2,303 Views)
If you have support for Traditional NI-DAQ installed, you should have the option to open a configuration file from: Tools>>Traditional NI-DAQ Configuration>>Set Active Configuration. You can check the installation of Traditional NI-DAQ under the Software tree in MAX.
Hope this helps.
Erin
(2,303 Views)
