I am creating an analog input task using the "Create Virtual Channel" VI, in RSE mode.
How would I modify some of these channels to use a different mode (differential) or a different max / min voltage?
If I create a channel property node, can I wire a string constant into the "ActiveChans" terminal, and then set whatever properties I want? If not, how would I specify the channel(s) I want to modify? Any help would be greatly appreciated!
