Multifunction DAQ
How can I call NI-DAQmx with Borland Builder C++?
I don't know if I can use NI-DAQmx with Borland Builder C++.
If yes How can I?
I cannot use traditional NI-DAQ because when I run program linked with them I have a PC crash.
Thank You
Begos
(2,689 Views)
someone has already answer your question:
http://forums.ni.com/ni/board/message?board.id=231&message.id=2989
If you have installed NI-DAQ driver in your PC, you can find examples exploring C:\Program Files\National Instruments\NI-DAQ\Examples\DAQmx ANSI C
You should avoid posting the same question in many threads.
Regards
MarcoC
(2,680 Views)
