I'm looking for the quadrature encoder in the DAQ Signal Pad.
I Must setting a Virtual Knob in the same position of the real knob.
For this I've wire the Channel A of the quadrature encoder with the Timer 0 Source.
I used the functions in the Easy I/O Library:
On application starts:
CounterEventOrTimeConfig (1, "0", ONE_COUNTER, USE_COUNTER_SOURCE,
COUNT_CONTINUOUSLY, COUNT_ON_RISING_EDGE,
UNGATED_SOFTWARE_START, &taskID);
CounterStart (taskID);
on Timer:
Variables
short overflow;
long counts;
Code:
CounterRead (taskID, &counts, &overflow);
SetCtrlVal (gui, PANEL_NUMERICKNOB, counts);
break;
It counts only up but not down when I rotate it clockwise.
I use the DAQPad-6020E
From The Manual:
E Series DAQ Devices
Connect phase A to the SOURCE of counter 0. Internally, phase B is
connected to DIO6, which is the up/down line for counter 0. Do not
wire the phase B terminal when using the quadrature encoder with an
E Series DAQ device. If you configure counter 0 for hardware up/down
counting, counter 0 will count up when the up/down line is high and
count down when the up/down line is low.
For example, if counting on the rising edge of phase A, as shown in
Figure 4, the up/down line (phase B) is low when the quadrature
encoder is rotated clockwise and high when it is rotated counterclockwise.
Can someone help me?
Message Edited by MaTy on 05-12-2005 10:26 AM
