Multifunction DAQ
Help with FRQ8 Freq/Period Meter
Is anyone using the SCXI-FRQ8? I recently purchased one and after finally
acquiring the proper driver files and finding out that a French company is
actually the developer (good luck getting any support out of them, I tried!)
I still can't get it to work!
I've installed it per the 'User's Guide', fired up the demo VI's that came
with it, fed in a 1 kHz square wave from my signal generator, and Voila! it
doesn't do a thing.
If anyone has used the FRQ8 (its got a 1301 terminal block on the front end)
and has had any similar experience that might help me out, I'd most
certainly appreciate it!
Russ Longdon
Message 1 of 1
(4,104 Views)
