Has anyone successfully loaded NI-DAQmx 8.0.2 in Ubuntu OS system version 12 or above ?
I understand that NI-DAQmx 8.0.2 - National Instruments is for RedHat and SUSE, but has anyone tred to enable it on Ubuntu OS system? <script src="//assets.adobedtm.com/a3a673425858388bc1b1e0ed01eb252ad8ce12e0/satelliteLib-1401ce0fc9dae9e8602fcc34896d0a249c42abb2.js"></script> <script src="http://assets.adobedtm.com/a3a673425858388bc1b1e0ed01eb252ad8ce12e0/mbox-contents-9016c8547b1ac2c743... <script src="//cdn.tt.omtrdc.net/cdn/target.js"></script> <script src="http://ni.tt.omtrdc.net/m2/ni/mbox/standard?mboxHost=www.ni.com&mboxPage=1439574199295-604598&screen... <script src="/widgets/pnx/1.0/js/ni.core.min.js"></script> <script src="/widgets/jquery_cookie/jquery.cookie.js"></script> <script src="/widgets/pnx/1.0/js/pnx.autocomplete.js"></script> <script src="/widgets/pnx/1.0/js/jquery.dotdotdot.js"></script> <script src="/widgets/pnx/1.0/js/panels.js"></script> <script src="/widgets/pnx/1.0/js/PIE.js" type="text/javascript"></script> <script type="text/javascript" charset="utf-8">// NI.require({ css: [ "/widgets/jqueryui/1.9.2/css/ni/jquery-ui.css", "/widgets/pnx/1.0/css/messaging.css", "/css/drivers/drivers.css", "/css/global/neutral/editmode.css" ], js: [ "/widgets/jqueryui/1.9.2/js/jquery-ui-1.9.2.custom.min.js", "/widgets/pnx/1.0/js/collapse.js", "/javascript/drivers/drivers.js" ], priority: "high" }); // </script> <script src="http://assets.adobedtm.com/a3a673425858388bc1b1e0ed01eb252ad8ce12e0/s-code-contents-523d44688c97ac3a...
(4,549 Views)
Hi Nintel,
As you said, here in National Instruments we do not support our porducts in Ubuntu OS, however I did some research about your question and I found some information that could be useful for you,
1- How can I install NI-DAQmx on ubuntu 14.04
https://decibel.ni.com/content/thread/25501?tstart=0
2- http://ubuntuforums.org/showthread.php?t=1807043
3- Installing NI-VISA and DAQmx on Ubuntu 10.*
http://pourounas.blogspot.com/2011/03/installing-ni-visa-and-daqmx-on-ubuntu.html
4- How to Install Nikal1.1+NI488.2+NiVisa4.5+PyVisa+NIdaqmxBase on Ubuntu 8.04 (Only for human beings)
5- How to install NI-DAQmx 8.0.1 on Ubuntu 10.10 (Maverick Meerkat) 32 bit
I hope that some of these information result useful for you!
Regards
(4,358 Views)
