Thanks for the advice, but Im pretty sure that isnt a timing thing.
I am running DAQmx as that is the only thing supported by the DAQPAD.
If I run the DAQPAD by itself, I get the same delay. What I mean is, I have an accelerometer connected to the AI channel. When I start the VI, if I tap the accelerometer, I see the signal immediately on my graph. After about 5 minutes, when I tap the accelerometer, it takes 2 to 4 SECONDS for the signal to appear on the graph. If I do a series of taps, they all show up, eventually, so I know I am not losing data, it is just arriving late.
I used an identical sensor with my DAQCARD and the same VI and there is never a delay. Running both at the same time, you can see they are syncronized at first and then the DAQPAD slowly falls behind.
Ill try the sync thing just to see what happens, but im not optomistic.
pete.
