Multifunction DAQ
Great connectors found to work with BNC 2110, BNC 2120, BNC 2121, etc. BNC to 2-wire connectivity
If you need to go from BNC to two wire connections when using Multifunction DAQ, I've discovered two useful BNC adaptors from www.pomonaelectronics.com . They are: Pomona 4969 and 4970. The first is BNC Female to two wire and the second is BNC Male to two wire adaptors. This enables us to use BNC cables to make nice clean BNC connections on the NI connector blocks and at the other end break out to two wires for connection to various (non-BNC) signal conditioning devices.
(2,978 Views)
Hello Rob,
Thanks for this info....Much appreciated!
-Alan A.
(2,967 Views)
