12-14-2016 09:28 AM
I ment 'one wave' produced by all 3 you know? Like a rms. In your example there are still all 3 signals by themself(in one wavechart) visible.
12-15-2016 01:36 AM
03-09-2017 09:49 AM
Hey Alex,
need your help again.
- I Need to save on my PC the data i have measured
- therefore it should exist a field with "save under"
-than a new (second or third and fourth.... etc) analysis/measurement should be done
- all of them Need to be saved
-there should be a list/window where I can see and select the measurements/data
-to make a conclusion between the measurements, I want to upload the saved datas in the diagramm to see the differences between them.
It should just work for the FFT and Hüllkurvenanalyse
Do you think it´s possibile to create this?
Thank you for your help.
If something is hard to understand let me know 🙂
03-09-2017 02:14 PM
Hello Gregory88,
yes, everything is possible you are the programmer, you can do it.
1. Split acquisition from the data analyse and save functions with a producer consumer architecture, which uses a queue.
2. Implement in the consumer a statemachine so you can periodically save the values.
3. With the recrusive file list.vi function you can made list of the files, then select the needed and display them in a graph.
4. The statemachine can be extended to manage all the needed functionallitis.
5. Also a event structure can be helpfull to manage the controls and Buttons.
03-10-2017 08:39 AM
Hi Alex,
for you it seems to be so easy 😕
1. ok i think the producer consumer architecture is a scheme like this?
http://www.ni.com/white-paper/3023/en/
2. state machine is like this?
http://www.ni.com/tutorial/7595/en/
3. where to download the recursive file list.vi
cant find it online, even not in LabVIEW
... dont know how and where to start, still in war with LabVIEW
03-10-2017 03:31 PM
Hello Gregory88,
not optimized, no event structure, no error handling and many things that can be done better, but a starting point.
03-13-2017 09:44 AM
could you please send me the vi in LabVIEW 2015
thanks a lot
03-13-2017 09:51 AM
03-13-2017 12:12 PM
Thank you Alex,
i cant move the x-axis from "alle Spannungssignale getriggert" after the measurement stoped in correlation with the "Messdauer in Sekunden". (Also mit dem Drehregler konnte ich vorher die x-Achse skallieren wenn die Messung vorbei war)
In the diagram "Aufgezeichnete Messwerte" it´s now possible to compare the measurements with each other, but after uploading the data in the diagramm, how to get them also in the FFT/Hüllkurve to compare them there?
Is it also possible to select the files by mouse? Otherwhise it´s also fine like this.
Best regards.
03-14-2017 03:32 AM
Hello Gregory88,
the state machine loop only run if the acquisition runs, additional the select of the TDMS files in a table.
I think it is also time to clean up diagram and front Panel.
