Hey Guys,
The fourth voltage is not scaling properly. Can any of you tell me why? I have two scaling choices, notice that the fourth one is different from the first three
When I put 5VDC on Analog Channel 22 I get about 638 psi out, I think it should be about 15000 psi with that scaling factor . . .
When I use the other scaling choice I get what I expect, about 10000 psi. This should be easy, right?
-Rick (using LV 7.1)
