Hello
I've tried to fit the data which is supposed to be a Sine function with LabVIEW 7e. I found "Tone Measurements" in the analysis which tells the amplitude, phase, frequency.
The problem occurs when the data is expected to be the sine function with "offset". Actually, I have to find the way to deal with the offset. Does LabVIEW support that kind of routine?
Thanks, GraceSun
