Hi ALL,
I'm using USB-6343 for both Digital and Analog measurement at the same time.
1) 16 digital inputs, I do the measurement in parallel and use queue. One side I'm non-stop collecting input data, on the other side I process data and do the TDMS logging.
2) 16 analog inputs, I use a for-loop for them cause I need a high sampling rate. Also I use queue and do the TDMS logging.
For the programming, it can run for some time sometimes, but also very often I can get following 2 errors. Can anyone give me help about this?? Many thanks.
1)
Error 6 occurred at TDMS Close in DI_data_log.vi:1680015->DI_wave_demulti.vi->Fan_OVEN_Test.vi
Possible reason(s):
LabVIEW: Generic file I/O error.
2)
Error 8 occurred at TDMS Open in DI_data_log.vi:1680015->DI_wave_demulti.vi->Fan_OVEN_Test.vi
Possible reason(s):
LabVIEW: File permission error. You do not have the correct permissions for the file.
