04-19-2016 04:47 AM - edited 04-19-2016 04:57 AM
I'm trying to use a CRIO 9081 with the modules NI9206. Max recognize the chassis but not the module.
When i try to add a DAQ associated to the NI9206 in Veristand, the error message 200220 it appears.
04-19-2016 09:27 AM
Hi vincentlg,
and how are you accessing the channels? Do you use a task or you access the physical channels directly?
04-19-2016 10:07 AM
I try to access the physical channels directly, juste by adding a DAQ in the system explorer to get an analogic input.
The modules are connected but Veristand but he mentions that the device is invalid...
04-20-2016 01:39 AM
And is the project properly configured?
You can see the guidelines here (most important is the OS and IP): http://www.ni.com/tutorial/14126/en/#toc2
04-20-2016 03:03 AM
I find the solution, finaly it was necessary to add a custom device to scan for new engine and to detect the modules. Then it's possible to interact with modules.
Thank you for your help !
04-20-2016 03:21 AM
Great!
Have fun 🙂
