NI Home
Cart Cart | Help
You are here:
Reply
msamman
Accepted Solution
Error -200077 with NI USB-6008
I am trying to run the sample C program that came with my NI USB-6008 DAQ card. I am trying to run the "ContGen-ExtClk.c" example. I get the following error when I build the program:
DAQmx Error: Requested value is not a supported value for this property. The property value may be invalide because it conflicts with another property.
Property: DAQmx_SampTimingType
Requested Valeu: DAQmx_Val_SampClk
You Can Select: DAQmx_Val_OnDemand
Task Name: _unnamedTask<0>
Status Code: -200077
End of program, press Enter key to quit
Thanks for any help.
Knight of NI
Dennis_Knutson
Re: Error -200077 with NI USB-6008
Did you do a search for that error code? As you can see from the specs for the 6008, the analog output is only software timed so you can only select OnDemand timing. Your actual update rate is going to vary quite a bit and, according to the specs, have a max of 150S/s.
msamman
[ Edited ]
Cool Thanks!
