09-18-2014 11:10 AM
I want to connect my cDAQ 9188 on the Measurement and Automation Explorer. I do find the device in the network, but when I chose "connect/add device" i get an error...
I`m sorry, I can`t translate it but it says:
Hinzufügen des Geräts fehlgeschlagen. Das Fehlerprotokoll des Gerätetreibers lautet wie folgt:
Gerät hinzufügen:
-201401
Das Erfassen von Eigenschaften vom Netzwerkgerät schlug fehl. Stellen Sie sicher, dass das Gerät verbunden ist.
Angegebenes Gerät: cDAQ9188-18A4773
Eigenschaft: TCPIP.HostName
Zugehöriger Wert: cDAQ9188-18A4733
Thanks for help.
09-18-2014 11:48 AM
It says:
"Retrieving properties from the network device failed. Make sure the device is connected."
Can you give some more information about how the 9188 is connected to your system/network?
09-18-2014 12:18 PM
09-19-2014 02:54 AM - edited 09-19-2014 02:59 AM
Hello basti323,
on the 9188 is a reset button, push this for more then 10 seconds
after reseting the device, DHCP is activate and if no server is found
a link local address will be generated.
Check your network address from the pc, it should be a link local
like this 169.254.x.x and the subnet should be 255.255.0.0.
Under start write services.msc and in the services view disable
the windows firewall service.
Open the MAX press F5 and under devices-> network the
chassi should be shown.
If the device is found in MAX the firmware on the 9188.
Network cDAQ Troubleshooting Resources
Hoep this helps.
