Signal conditioning is one of the most important, and most overlooked, components of a PC-based data logging system. Most signals require some form of preparation (conditioning) before they can be digitized.
Any time a thermocouple is connected to a data acquisition system, the temperature of the connection must be known in order to calculate the true temperature the thermocouple is measuring.
The following links will help you understand the useage and also show you signal conditioning modules offered by National Instruments.
What is the Recommended NI Hardware for Thermocouple Measurements?
A Review of PC-Based Data Logging and Recording TechniquesThermocouples
SCXI SupportLet me know if you have further questions.
Good luck and have a great day!
Koninika
http://www.ni.com/support
