07-07-2005 05:01 PM
07-08-2005 04:20 PM
Hello Azazel,
I'd like to ask you some questions if I could:
1) Are you using an external clock, or internal?
2) Are you doing a finite or continuous acquisition?
3) You mentioned that the sample rate is cut in half when you sample two channels. This certainly should not happen, how are you verifying this behavior?
It is also important to mention that that 10M Samples per second on 4 channels with 16 bit data is 80 MB/sec worth of data. This is a lot of data to manage. Are you going to be writing to disk, or just displaying the data? You will probably want to consider reading raw or unscaled data.
-Alan A.
07-08-2005 09:49 PM
07-11-2005 02:21 PM
07-11-2005 02:55 PM
