08-05-2015 01:21 PM - edited 08-05-2015 01:21 PM
Is there any particular option or way available in LabVIEW to initiate the data acquisition and high speed camera using a digital start trigger? If yes, shall I create a task for high speed camera and then synchronize it with the other tasks?
Kind Regards,
08-06-2015 03:00 AM
Hi Helen19411,
The way to trigger data acquisition in LabVIEW is to use the 'DAQmx Start Trigger VI'. To set this up I recommend taking a look at this example:
http://www.ni.com/example/25282/en/
Without any information about the high speed camera you are using, I can't give much advice. If the device is viewable in MAX then you may be able to create a task, and so long as you synchronise both channels in your code, the digital trigger should activate both events.
Kind Regards,
TomS
