I'm trying to control a motor which has a potentiometer as it's position sensor.
I need to perform functions on this analog input data in order to send out a digital signal, which will control valves etc.,.
My problem is that the following error signal is occurring and I don't know how to fix it.
All I want to happen at the beginning is for a TRUE value to yield a positive output on my DAQ.
When I had the digital output DAQ in a while loop, the value turned FALSE once it got inside the loop.
Any help would be much appreciated.
"Write cannot be performed, because the number of channels in the data does not match the number of channels in the task.
When writing, supply data for all channels in the task. Alternatively, modify the task to contain the same number of channels as the data written.
Number of Channels in Task: 1
Number of Channels in Data: 100
Task Name: _unnamedTask<65>"
Message Edited by Support on 03-08-2005 07:46 AM
