Multifunction DAQ
Different sampling behavior with different CDAQ chassis
I am setting up a strain gauge measurement and right now I have a full bridge set up made entirely of resistors, just to verify my test set-up. I have been using a 9219 module with a 9171 chassis and I have been able to get the sampling behavior I want using these parts. My sample frequency is 20S/s and I get 20 distinct samples per second using this set-up (measuring V/V).
Inline image 2
I also have a 9174 chassis that I would like to use instead so I can incorporate other measurements. For some reason, just switching out the chassis and using the exact same LabVIEW code results in different behavior. This is the data I get with the 9174 (same module):
So, technically it is giving me 20 data points per second but I have no idea why the values aren't changing every sample. My understanding is that the sample rate the DAQ is capable of is dependent on the module, not the chassis -- so why would changing out the chassis result in this change in behavior?
If anyone has any ideas here, they would be greatly appreciated. Thank you!
(2,552 Views)
Accepted by topic author AmandaBacala
Figured it out -- apparently I had the timing mode of the device set properly for the 9171 and not the 9174. I added a property node to the LabVIEW code to set the timing mode to High Speed (image attached) so I believe this would fix the issue for any new chassis. I am now getting 20 distinct samples per second with both chassis.
(2,536 Views)
