10-05-2015 12:51 AM
we are building a new laboratory setup which will require Hardware in the Loop data sensing by the sensors , and formatting/ analysis using programs and possibly sending data back to hardware for control.
We are confused as to the BNC shielded connector block ( which has analog/ digital inputs and outputs) or a DAQ device to be used?
what are the major difference between them?
any light upon the above is highly appreciated..
Fesmi
10-05-2015 07:04 AM
The DAQ is what does the actual measuring of the signals. The terminal block is just a simple way to route the signals to the DAQ. So you will actually want the terminal block, cable, and the DAQ card.
I highly recommend talking with your local NI sales rep to make sure you get exactly what you need.
10-13-2015 12:43 AM
Hi cross rulz,
Thanks a lot for the reply.
As per your advice we contacted the Ni rep here at Middle East , and he has provided us with quotes for DAQs which best fit our application.
Fesmi
