02-29-2012 07:17 AM
Hi!
I have two 6501 NIDAQs that I'm using in two different PCBA test equipments. The names I've given them are "Dev1" and "Dev2". For some reason they can't be plugged into the same computer at the same time (USB), since my LabView/TestStand application doesn't seem to be able to tell the one from the other.
If I run my first test, using Dev1, and later try to run the second test, now using Dev2, my DAQAssistant - even though I can see that Dev2 is sent to its "DeviceName" - still is communicating with Dev1.
Now, if I unplug either one of them and then run any of the tests, it will crash because of "unnamed task". If I then go to NI Max and just click "Create Task..." and the cancel, it will work until I plug in the other device and disconnect my current one. I now will have to repeat the "Create Task..." step to get my new device to work properly.
Is there anyone who has had a similar problem and have been able to solve it?
Solved! Go to Solution.
03-02-2012 06:48 AM
If you create a task in MAX (or DAQAssistant) it also saves device info with that task.
For example: Lets say you create a "Voltage" task with device "Dev1"; you then connect "Dev2". The "Voltage" task won't be able to use "Dev2" because it has "Dev1" channels assigned to it.
The solutions would be:
These are some of the options of the top of my head, there are probably more.
Best regards
Matej
03-02-2012 09:52 AM
Hi
Thanks for the help.
It turns out the problem was the TestStand load option. If I choose to unload every step after the execution of the sequence file, the problem is solved.
Regards
Kristian
03-06-2012 01:46 AM
Just an update; I'm not sure the second solution will work. I tried something similar and it didn't.
Matej
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
