Determining specifications of the PCI-6221
I tried looking at the specifications on the website of the PCI-6221, I can not determine if it has certain signals available. I could not determine if there was an analog output ground (AOGND), external control signal to start timed conversion sequence (EXTTRIG), and external control signal to trigger A/D conversions. These three pins are in use on my current board, and I need to know if they're available on the PCI-6221 I'm going to purchase, or if one of the other pins can be used for the same purpose. Thank you for your help.
Kathleen
(2,852 Views)
Hello Kathleen,
you can go on the NI site, at adress: http://digital.ni.com/manuals.nsf/websearch/DD0F3F9A89B8A84886256EE6006D520D?OpenDocument&node=14136_US
and download the "M Series help" files (zip).
After unzip, you can open the help file M_Series_Help.chm, and find all what you want to know (searching words like "pinout", or "I/O connector").
Have a nice day.
(2,852 Views)
The new M Series boards are a little different, but I think that you will agree that they are better. On E Series, timing and triggering outputs on the 68-pin connector are tied to specific pins and the inputs are programmable, hence PFI (programmable function inputs). On M Series the outputs and the inputs are fully programmable, hence PFI (programmable function interface). The timing and triggering signals on M Series don't have default pins and therefore are not as obvious on the pinout. All of the timing and triggering signals that you describe are available on M Series and you can route them into and out of the M Series board on whatever PFI pin you would like. Good luck.
(2,852 Views)
