08-04-2005 09:33 AM
Hello all,
I'm trying to trigger labview to take a finite number of samples from Ai0 based on an internally generated counter (CO Pulse Time).
The sampling triggers perfectly well off the rising edge of the digital signal but although I've added a property node to control the start delay (delay before labview starts acquiring data) this has no effect on when Labview starts to acquire the . Am I using the property node incorrectly?
Cheers,
Bob
I've attached my code.
The bottom half is where the counter pulse time is generated and the top section is where acquisition from the Analogue input takes place. I linked the counter output to the analogue input so that I could check what delay I was adding. I should theoretically be able to delay the trigger so that Labview starts to acquire data after the ~5V counter pulse has stopped but this isn't the case. It always starts acquiring data immediately when triggered.
08-24-2005 05:26 AM
08-24-2005 05:33 AM
08-24-2005 05:41 AM
08-24-2005 05:51 AM
