11-27-2006 01:48 PM
When I try to load the sample code for "Acq-Int Clk" for example, I get the following error:-
"DAQmx is not member of NIDAQmxCAPI"
Here is a snippet of the code that causes the problem but the same thing appears in other places as well
'Create the DAQmx task.
DAQmxErrChk(NIDAQmxCAPI.DAQmx.DAQmxCreateTask(
"", taskHandle))11-28-2006 11:36 AM
11-28-2006 03:51 PM
Thanks Ken,
I think this has me on the right track now.
08-12-2016 11:22 AM
Hi Keen,
I am facing the same problem when trying to convert code from Visual Basic 6.0 to Visual Studio 2008. The code example I found is in:
C:\Users\Public\Documents\National Instruments\NI-DAQ\Examples\DAQmx ANSI C\Analog In\Measure Voltage\Acq-Ext Clk
According to the example, I replaced the original code in Visual Basic 6.0:
DAQmxErrChk(NIDAQmxCAPI.DAQmx.DAQmxCreateTask("", taskHandle))
With
DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
However, the code still does not work, saying the DAQmxCreateTask is not declared
I was wondering if you wound be willing to provide me some sugestions?
Thanks!
08-15-2016 08:49 AM
bwang,
Are you able to run the example code without any problem? Can you post your code here so we can see what else might be going wrong?
J. Calvert
08-24-2016 03:12 PM
Hi Kathryn,
Thank you for your help.
I am now converting VB6 to VS2012 instead. The examples in
C:\Users\Public\Documents\National Instruments\NI-DAQ\Examples\DotNET4.5
are useful!
Besides,
1. I changed target framework from ‘.NET Framework 2.0’ to ‘.NET Framework 4.5’
2. I added "National Instruments Common" and "National Instruments DAQmx" as the references.
It works now.
