01-25-2016 09:05 AM
Hi
When using MAX, there's always the option to have a look at a neat connection diagram that makes it obvious for anyone how the wiring should be set up (such as here) given a particular task/channel configuration. Is this information available through the NIDAQmx driver? I'm struggling to find anything relevant in the API documentation.
FYI, I'm using USB-6212.
Kristaps
01-25-2016 09:40 AM
01-25-2016 10:01 AM
Not even just generic information of pairs of terminals that one must use for each channel? Ach well.
I just found that this is all listed in great detail in the user manual (section 3 here). Was just hoping that all the info is already available from the API as well.
01-26-2016 12:54 PM
There are also pinouts for supported DAQ devices in the NI-DAQmx Help, but Connection Diagram is currently only available through MAX and the DAQ Assistant.
10-11-2016 07:54 AM
I was frustrated by this lack of API as well so I dug into the DAQ Assistant code, but couldn't find anything useful since I think the part that actually generates the image is embedded in the application, and isn't native G code.
Still I made an idea on the idea exchange for making this a public API.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
