Hi Logan,
Thanks for your reply.
I reinstalled MAX and NI-DAQ 7.2 three times and the problem remains. During my last try I also delete the MAX directory under National Instruments directory. My other PXIs (some with the same controller but different chassis) don't have this problem.
I also disabled legacy USB support as suggested
here. On this PXI I'm running Windows 2000 as well.
Another thing I tried is to run the PXI Provider.msi included in NI-DAQ 7.2 to repair the pxi provider, after a complete installation is done.
As for routing low or high to RTSI, actually I've done it before and it seemed to work
fine. I created a pulse (low-high-low) on RTSI line and used it as a start trigger for all the counters on a 6602. That's not the purpose of the RTSI line but I think it's still feasible to do.
Dan
