05-06-2008 02:50 PM
05-07-2008 05:06 AM
Hi:
There is one important thing you should check,
the device name is your promgram must be same with the name in Measurement & Automation Explorer. For example, if your 6711 DAQ card is named "Dev3" in Measurement & Automation Explorer, u must use the same name "Dev3" in your program.
NITW JAY
05-08-2008 02:59 AM
05-08-2008 04:27 AM
HI:
You can download the DAQmx driver in http://www.ni.com/support/
Before u download the driver, u must check the compatibility between your Labview
and Windows.
http://digital.ni.com/public.nsf/allkb/97D574BB1D1EEC918625708100596848?OpenDocument
NITW AE JAY
05-10-2008 12:15 AM
