If I understand what you want, you need to trigger an analog acquisition from an external digital trigger.
By default, the Start Trigger signal is internally routed to the PFI0 line of the front connector.
To configure your device to start acquisition on rising edge on PFI0, you can use the following examples provided with LabVIEW (Menu Help >> Search examples...):
* Hardware Input and Output >> Traditionnal DAQ or DAQmx >> Analog Input.
Please let me know if it helps.
Matthieu Gourssies
National Instruments France
