10-28-2016 12:40 PM
I have a few basic questions about the PXIe-6363 DAQ which I haven’t been able to find an answer to.
At this point I’m laying out a PCB, so mostly the answers I need at this point are concerned with capabilities, so I don’t connect things up incorrectly.
I’d like to configure the pins as follows:
P0.0 | Static digital output | These can be grouped together into a 4-bit nibble |
P0.1 | Static digital output | |
P0.2 | Static digital output | |
P0.3 | Static digital output | |
P0.4 | Waveform output, 240 Hz, 10% duty cycle | Must be independent |
P0.5 | Waveform output, 240 Hz, 10% duty cycle | Must be independent |
P0.6 | Not defined yet, probably input | Could be analog sample clock or trigger |
P0.7 | Not defined yet, probably input | Could be analog sample clock or trigger |
P0.8:31 | Static digital output | These can be grouped together into a 24-bit word |
P1.0:7, P2.0:7, or PFI.0:15 | Not defined yet | Will use these if necessary |
In short, do I need to break up the types of functionality into different ports like P0, P1, P2 or can I mix and match individual pins?
Solved! Go to Solution.
10-31-2016 03:14 PM
Here is a document with some info: http://digital.ni.com/public.nsf/allkb/8058F1BEF0944D99862574A3007EB53C
Let us know if that clarify all your doubts...
Regards!
10-31-2016 03:36 PM
Thanks, that link is not working.
10-31-2016 04:22 PM - edited 10-31-2016 04:22 PM
The link has a space at the end. Just remove it and it will work
Here it is again anyway.
10-31-2016 05:50 PM
Thank you.
Does this imply that non-PFI lines can do static digital IO indpendently, but not output waveforms?
11-01-2016 12:13 PM
They can output digital waveforms. the difference between these and the non-PFI ones is that these could also do Timing I/O for digital and analog tasks or counter/timer functions.
11-01-2016 01:03 PM
Thank you for the response. I think this means I can leave my digital lines connected as is, since I don't need timing or triggering, just a waveform output.
11-01-2016 02:09 PM
- What is the difference in functionality between P0/P1/P2 and the PFI functionality allowed on P1/P2?
PFI pins offer some functional and routing options that can be used to carry timing signals to and from AI, Counter, and other tasks. No port 0 pins offer PFI functionality. However, *only* port 0 can be used for hw-timed digital tasks. Ports 1,2 only support software-timed digital i/o.
- Using DAQmx (C interface) what API functions should I look at for selecting the functionality PFI or non-PFI? I don’t need a lot of detail, just where to look.
Sorry, no help, I only know the LabVIEW API.
- For a given port, such as P0, can some IO pins be configured as static outputs, others as waveform outputs, and others as inputs, simultaneously, assigned presumably to different tasks in DAQmx?
Yes, but with some restrictions. See below.
- For a given port, such as P0, can some pins be configured as PFI and others as non-PFI?
No, not on P0. Board design dictates that those pins cannot have PFI functionality. On P1 (or P2) you may use some lines for DIO and others for PFI functionality. Mix and match as you like.
- Do I need PFI to generate a pulse waveform output on a given pin, such as 240 Hz, with 10% duty cycle?
Exactly the opposite. Only port 0 with no PFI capability would support the hw-timed pulse waveform as a Digital Output. (However, you could make a counter task for that digital pulse train and route its output to a PFI pin on ports 1 or 2).
P0.0
P0.1
P0.2
P0.3
P0.4
Must be independent
P0.5
Must be independent
P0.6
P0.7
P0.8:31
Not defined yet
The only potential conflict I see is P0.4 and P0.5. You can only run one hw-timed task at a time for all your DO pins. It's allowed to have multiple lines in that one task, but you won't be able to manipulate the start/stop/freq/duty cycles independently. If you were to run your freq/duty cycle pulse trains off of two counters and route to PFI pins on ports 1 or 2, you could control them independently.
-Kevin P
11-03-2016 10:37 AM
Thank you for your detailed answer. I'll consider whether I "really" need indepence on my two HW timed tasks.
